COPstance - plugin for Houdini
   19222   33   15
Hi, guys!
A new version 1.5.0 of the plugin is just released!
Now its name changed to COPstance.
- Added new basic node: Seamless Noise.
- Added patterns assets for Houdini Indie.
- Changed plugin installation method.
Enjoy!
https://copsubstance.com [copsubstance.com]
Follow COPstance on Twitter: https://twitter.com/copsubstance [twitter.com]
Great work here! I am trying it out and I love the functionality you added. One big problem is that I get a seg fault whenever using the Distance Node. This causes Houdini to crash
bananabeta
I just updated Copstance for Houdini 18. Try to download a new version from the site.
Edited by Quantico - July 28, 2020 14:43:32
Hi, guys!
A new version 1.6.0 of the plugin is just released!
- Added new node Tile Generator (more powerful than Tile node).
- Added new node Splatter Circular.
- Fixed memory leak in Distance node.
- Fixed error with connecting more than one input node to FX-Map node.
Enjoy!
any plans on implemented the fluid node in designer?
proGlammer
OK, it is interesting. I will try to add it.
Hello, everyone!
A new version 1.7.0 of the plugin is just released!
- Added new node: Fluid.
- Added new node: Liquid.
- Added new node: Simple Perlin.
- Warp node: added OpenCL support.
Enjoy!
Quantico
Hello, everyone!
Enjoy!
Tried to install the COPstance 30 day trial and Windows Defender suggests I don't open the .exe I don't assume it's a virus, but don't want to assume it's safe because I am guessing it's safe. What do you suggest?
Houdini 19 will be announced and released relatively soon I predict. Since I haven't seen activity from you recently, I just want to make sure there is going to be an update for your plugin for 19 in a timely fashion.
vstevenson
It is because of the specific work of Windows Defender. It is based on download and launches statistics. It marks all files with low launch statistics as suspicious.
If you worry about it, you can check the file on virustotal.com
vstevenson
Yes, I will out a version for Houdini 19 as soon as it will release.
Hey,
I got your plugin. It works partially, some nodes don't do anything e.g. tile? I see the same image, without any tiling of my picture.
Another question, when I try to add COPstance patter, houdini wants to swith to non-commercial, why? Is it possible to stay in commercial and use patterns?
image 55.png (73.5 KB)
overdoseby
Hey,
This is the default behavior of such types of COP nodes (with Image tab) in Houdini.
You need to go to Image type of Tile Generator and change Add Plane parameter from M to C, A (Color planes with alpha)
overdoseby
Go to the plugin folder and remove sbs_patterns.hdanc file from otls folder. There must be left sbs_patterns.otllc file. This is for Houdini's indie license.
Hello, guys!
The version for Houdini 19 (Build 383) is already out!
As always you can download it from the site. There is nothing new, but it works with Houdini 19)
It's such a great plugin! Thank you very much.
Hi, guys!
A new version 1.8.0 of the plugin is just released!
– Added Weave 1, Weave 2, and Weave Generator nodes (in Substance Patterns menu).
– Rewritten Cube 3D node in native C++ that improved its performance. Also added OpenCL support and Offset parameters.
– Rewritten Shape Mapper node in native C++ for better performance (also with OpenCL support).
– Fixed rare OpenCL problems for all nodes.
– Improved interface for Arc Pavement node, added Pattern Specific, Pattern Variation, Minimum Width, and Minimum Height parameters.
– Fixed work of Transfromation 2D node.
Enjoy!
