Need help for rolling a line into a spiral
11967 10 1-
- constantgenerator
Hi, I'm new to Houdini and I am struggling with one task which I thought will be simple.
I have a line with 50 points (I tried with a line, curve and just copied points) which I am trying to bend into a spiral (I tried using bend, but it makes perfect circles, and I want a spiral, I also tried to use attribute wrangle to set rotation on points manually, but I was not able to set correct pivots for each point, they all have the same pivot).
What is the approach here in general if I want to roll something into a spiral.
The thing that I am trying to do is to roll rice mat into a sushi roll.
- CYTE
- 805 posts
- Midphase
- 833 posts
SideFX Labs Spiral?
https://www.sidefx.com/products/sidefx-labs/sidefx-labs-tools/ [www.sidefx.com]
I made a tutorial on SideFX Labs excellent set of tools, including Spiral. You can watch it here:
>>Kays
- vusta
- 555 posts
- anon_user_38315714
- 340 posts
It is interesting to see different ways to do this. I would use an attribute expression node to make this spiral. If you allow editing of contents on the lab spiral solution, you can see how they did it. But here is a three node solution (with a couple extra nodes to create a sushi wrap.
Update, I realize this is probably what was meant by point sop.
Edited by anon_user_38315714 - May 15, 2020 18:49:18
- animatrix_
- 5189 posts
#include "math.h" #include "voplib.h" float easeOutCirc ( float t ) { return sqrt ( 1 - ( pow ( ( 1 - t ), 2 ) ) ); } float index = @ptnum; float numpts = @numpt; float startAngle = radians ( ch("angle") ); float dir = 2 * ch("dir") - 1; float steps = ( numpts - 1 ) / ch("turns"); float stepAngle = ( 2 * PI / steps ) * dir; float inc = index / ( numpts - 1 ); int mirror = chi("spherical"); float linear = ( 1 + mirror ) * inc; if ( mirror && index + 1 > numpts / 2 ) linear = ( 1 + mirror ) * ( 1 - inc ); float circ = easeOutCirc ( linear ); float interp = linear + ( circ - linear ) * ch("roundness"); float r = ( ch("rx") + interp * ( ch("ry") - ch("rx") ) ); // Apply power to radius at the end (after curvature) inc = ( ( numpts - 1 ) - index ) / ( numpts - 1 ); float theta = 2 * PI * inc; if ( mirror && index + 1 > numpts / 2 ) theta = 2 * PI * ( 1 - inc ); r *= pow ( ch("falloff"), theta ); float angle = index * stepAngle + startAngle; float x = sin ( angle ) * r; float z = cos ( angle ) * r; float h = index / ( numpts - 1 ); float y = vop_bias ( h, 0.5 * ch("bias") + 0.5 ); y = vop_gain ( y, 0.5 * ch("gain") + 0.5 ) * ch("height"); matrix3 xform = dihedral ( { 0, 1, 0 }, { 0, 0, -1 } ) * lookat ( 0, normalize ( chv("n") ) ); @P = ch("scale") * set ( x, y, z ) * xform + chv("t");
Create a line and copy this code inside a point wrangle node. Make sure to set Scale, Height, Ry, Falloff to a positive value like 1, Turns to 5, N to {0, 1, 0} if your input line is along Y. It can also create spherical spirals, etc.
- mestela
- 1868 posts
- Konstantin Magnus
- 729 posts
Or this:
float u = vertexprimindex(0, i@ptnum) / float(primvertexcount(0, i@primnum)); matrix3 m = ident(); float amount = chf('amount') * u; vector axis = {1,0,0}; rotate(m, amount, axis); v@P *= m;
- 340 posts
There are probably more elegant ways of doing this (and more mathematically correct), but here is an unwrap of a spiral with reasonable UV's. Note: due to changing number of points on spiral curve, the transform UV scale had to be keyframed on the extruded spiral. There is probably a simpler way of doing this, but I don't know it. The length of a spiral curve also does not have an exact solution in calculus, so I made a few approximations.
https://vimeo.com/420120985 [vimeo.com]
Edited by anon_user_38315714 - May 19, 2020 13:55:38
- 340 posts
I actually think Konstantin's method is better than mine (and Animatrix's method is particularly good for more complicated spirals). In mine, the ramp actually compresses the material during the unroll, which is undesirable. I modified Konstantin's method slightly, but I'm not sure how to get the UV's to map properly, but the shape itself is great. If anyone knows how improve the UV mapping, I would be curious. The only thing I can think to keep the UV mapping correct is to actually unwrap the spiral, using the method described in cgwiki.
Edited by anon_user_38315714 - May 21, 2020 10:41:27
- Konstantin Magnus
- 729 posts
I have improved the code and updated the hip file to illustrate it's working on multiple curves at once. As opposed to the usual @ptnum / float(i@numpt - 1).
int seed = chi('seed'); float u = vertexprimindex(0, i@vtxnum) / float(primvertexcount(0, i@primnum) - 1.0); float turns = fit01(rand(i@primnum + 12 * seed), 0.1, 1.0); matrix3 m = ident(); float amount = chf('amount') * u * turns; vector axis = {1,0,0}; rotate(m, amount, axis); v@P *= m;
Edited by Konstantin Magnus - May 21, 2020 07:33:45
