Attributes not showing up in Null Info
6500 3 1-
- AndreSerena
Hello there, I'm following a simple tutorial, and everything works perfectly, except, when the guy of the tutorial shows the info of his last Null node, he can see all the new added attributes and i did exactly the same process and in mine it doesnt show.. But everything works perfectly regardless.. its not logical at all.. maybe i'm missing something..
Edited by AndreSerena - June 16, 2020 13:04:35
- knoeterich
Hey there,
I am currently trying to get into Houndini a bit and I run into the same problem as AndreSerena.
When I try to do my own attribute like "bla" it shows in the node info but as soon as I write the attributes that are like predefined by Houdini I don't see them anymore in the node info.
What am I missing here?
Thanks for the help
Thanks for the help
- Berk_Erdag
- 86 posts
It seems to me copytopoints is not sending the attributes down the chain. Try to write * to the first attributes box of the copytopoints. It does not let some attributes through, by default it says *,^v,^Alpha,^N,^up,^pscale,^scale,^orient,^rot,^pivot,^trans,^transform which means everything except velocity, Alpha, Normals, pscale etc...
- Jimmybirdbox
