I have a question about the static argument for the onStartCook callback when implementing a scheduler. It seems like static always return False regardless if I do “Generate Static Work Items” or “Cook Output Node”. I would expect “Generate Static Work Items” to pass in static as True? Unless the static argument is not what I think it is.
Wayne W.
Scheduler: onStartCook static flag
1219 1 1- waynewu
- 10 posts
- chrisgreb
- 603 posts
static refers to a static graph cook, see onScheduleStatic:
sidefx.com/docs/houdini/tops/schedulers_callbacks.html#scheduler-callbacks
“Generate Static Work Items” performs the generation phase of a PDG cook. onStartCook is called, but the “static” in this case refers to the fact that no cooking of work items is performed, so no dynamic generation can occur.
