Hi everybody,
Is it possible to have control, with expressions, over the wirecapture parameters?
For example:
For each point in the controlwire you make U range a bit bigger.
perhaps with an expression like this.
point(“../resample1”,$PT,“P”,1)
Like this it would be possible to have bigger and smaller controlling regions along one single curve giving much better control for rigging and deforming.
WireCapture:possible to have per point control of wires?
2804 2 1- kgoossens
- 289 posts
- edward
- 7766 posts
Recall that when you're keyframing the lookup channel in the WireCapture, it's actually using “time” as the X axis. So instead of indexing by $PT, you should be indexing by $FF.
Note that the main benefit of using a lookup channel is so that the shape of the channel is free of the resolution of the points along the curve. So using the point() expression ties you back to the resolution of the curve. I would recommend using primuv() instead. For the “u” parameter, use something like ($FF-1)/239 where your lookup channel has first and last keys at frames 1 and 240 respectively. Using primuv() means you don't need to resample your curves either.
- edward
- 7766 posts
