Instances and motionblur
7224 5 4-
- sanostol
- 608 posts
This should be working, right? What do I miss here.
I tried both motion samples and v attribute and both have no effect. What do I have to add here.
In addition also vblur on a mesh seems to work not the way I at least would expect it, only the tree with samples on a mesh do blur at all.
Please have a look at the stage in the file
Thank You
Thank You
- sanostol
- 608 posts
- jason_iversen
- 13003 posts
Does it work if you use a Cache LOP (to author time samples)
- sanostol
- 608 posts
- 8177 posts
Cache lop didn't work for me in any case. Writing out the animation and reading with a sublayer was the only way to get it to work.
However, when closing houdini and reloading my file, it mysteriously works without any changes.
References:
Point instancer:
'Instanceable references' don't work correctly. The blur looks like when there are too many geometry samples when something is moving stochastically.
Instanceable References:
On a side note when using a point instancer prim, the prototypes would appear unhidden when changing the stage by loading a different file with the sublayer. Deleting the sublayer had the effect of re-hiding the prototypes. A similar effect happens when changing the instance method on the poinstancer lop. Deleting the lop and un-deleting also flushes the stage back to a working state.
Testing was with houdini 18.0.532
References:
Point instancer:
- sanostol
- 608 posts
Thanks for Your time, in 18.0.566 it You file also works with cache option.
Another question, I still have is rendering with v blur?
this does not work in any case here
Edit:
The problem gets even more unpredictable as soon as particle are reaped as they die. Another point for v blur approach. But still found no way to use vblur
As soon es I keep all dead particles I the motion blur does work again. But now I have to deactivate/hide them with the prune node based on the “dead” attribute.
My initial guess was to use the “usd_flattenedprimvarelement” vex function to get the right value for the instance, but I need a index, and @elemnum does not work. the documentation is vague, to say at least.
I think it is not supported yet, but I do hope im wrong.
Edit:
Edited by sanostol - Sept. 22, 2020 06:13:19
