how do you use Labs SciFi panels?
   5642   7   2
I tried using Labs SciFi panels on one side of a cube, when I clicked SciFi panel node, the cube disappeared. there is not much in help on this. how do you use it?
after your box, (best to have your box with divisions of 2x2x2)
- add facet>Unique points
- in scifipanels enable Generate New UVs
works on whole box, i'm sure you can wing it to isolate the effect on just one side of the box.
Edited by vusta - May 20, 2020 18:40:16
THANK YOU vusta, it worked perfectly.
I typically tend to use it with a Grid instead of more solid geometry.
>>Kays
Midphase
I have a model I am working well into and would love to incorporate SciFi panels into that model.
I've just been trying the SciFi Panels node and every time I actually connect it to any geometry Houdini just hard crashes. I'm just connecting it to a single quad. Does it still work?
The crash log has this callstack:
Crash report from John; Houdini FX Version 18.0.348 [windows-x86_64-cl19.16]
Uptime 367 seconds
Wed Oct 7 12:35:43 2020
Caught signal 11
Traceback from 8748 ThreadId=0x00005274
CURRENT THREAD 21108
+0x221032a8 [UT_EmbeddedTriangleMesh<GU_TriangleMeshDetailLinkT<float> >::operator=] C:\Program Files\Side Effects Software\Houdini 18.0.348\bin\libGU.dll
+0x22108edd [GU_TriangleMeshT<double>::buildMesh] C:\Program Files\Side Effects Software\Houdini 18.0.348\bin\libGU.dll
+0x1a31e340 [SOP_Measure_2_0Parms::copyFrom] C:\Program Files\Side Effects Software\Houdini 18.0.348\bin\libSOP.dll
+0x1a31bdd5 [SOP_Measure2::buildTemplates] C:\Program Files\Side Effects Software\Houdini 18.0.348\bin\libSOP.dll
+0x1a2ce342 [SOP_MeasureParms::version] C:\Program Files\Side Effects Software\Houdini 18.0.348\bin\libSOP.dll
+0x1a346b6a [SOP_Node::cookMyselfAsVerb] C:\Program Files\Side Effects Software\Houdini 18.0.348\bin\libSOP.dll
+0x1a31e022 [SOP_Measure2::cookMySop] C:\Program Files\Side Effects Software\Houdini 18.0.348\bin\libSOP.dll
+0x1a3459ad [SOP_Node::cookMe] C:\Program Files\Side Effects Software\Houdini 18.0.348\bin\libSOP.dll
+0x1201f48a [OP_OTLOptions::operator!=] C:\Program Files\Side Effects Software\Houdini 18.0.348\bin\libOP.dll
+0x1202cd6f [OP_Node::cook] C:\Program Files\Side Effects Software\Houdini 18.0.348\bin\libOP.dll
+0x1204af6b [OP_Node::internalCookInput] C:\Program Files\Side Effects Software\Houdini 18.0.348\bin\libOP.dll
+0x1204fb4a [OP_Node::lockInput] C:\Program Files\Side Effects Software\Houdini 18.0.348\bin\libOP.dll
+0x1a34e5d0 [SOP_Node::lockInput] C:\Program Files\Side Effects Software\Houdini 18.0.348\bin\libSOP.dll
+0x11f14fa1 [OP_AutoLockInputs::lockInput] C:\Program Files\Side Effects Software\Houdini 18.0.348\bin\libOP.dll
+0x1a343f12 [SOP_Node::cookGuide] C:\Program Files\Side Effects Software\Houdini 18.0.348\bin\libSOP.dll
+0x19d480fe [SOP_NodeVerb::cookInputs] C:\Program Files\Side Effects Software\Houdini 18.0.348\bin\libSOP.dll
+0x1a345cfc [SOP_Node::cookMyselfAsVerb] C:\Program Files\Side Effects Software\Houdini 18.0.348\bin\libSOP.dll
+0x1a33cd83 [SOP_Node::AttribTupleIndexArg::operator int] C:\Program Files\Side Effects Software\Houdini 18.0.348\bin\libSOP.dll
+0x1a34a7c1 [SOP_Node::getCookedGeoHandle] C:\Program Files\Side Effects Software\Houdini 18.0.348\bin\libSOP.dll
+0x19e4d3b4 [SOP_BlockEndFor::cookMySop] C:\Program Files\Side Effects Software\Houdini 18.0.348\bin\libSOP.dll
+0x1a707818 [SOP_Switch::cookMySop] C:\Program Files\Side Effects Software\Houdini 18.0.348\bin\libSOP.dll
+0x1a57b5bd [SOP_SubNet::cookMySop] C:\Program Files\Side Effects Software\Houdini 18.0.348\bin\libSOP.dll
+0x1a37fafd [SOP_Output::cookMySop] C:\Program Files\Side Effects Software\Houdini 18.0.348\bin\libSOP.dll
+0x1204fc3b [OP_Node::lockInputs] C:\Program Files\Side Effects Software\Houdini 18.0.348\bin\libOP.dll
+0x1a34e7c4 [SOP_Node::lockInputs] C:\Program Files\Side Effects Software\Houdini 18.0.348\bin\libSOP.dll
+0x1a40512d [SOP_PolyExtrude2::cookMySop] C:\Program Files\Side Effects Software\Houdini 18.0.348\bin\libSOP.dll
crash.TrimSheet01.John_8748.hiplc (519.3 KB)
OrangyTang
Uptime 367 seconds
Caught signal 11
did you enable generate new uvs ? or even update it from the ancient 348 version ?
just works…
Edited by vusta - Oct. 7, 2020 19:16:25
hello, does someone know if the sci fi labs node works only on native geo or could it also work on imported geo ->file?
