how do you use Labs SciFi panels?
5639 7 2-
- bobc4d
- 327 posts
- vusta
- 555 posts
- bobc4d
- 327 posts
- Midphase
- 833 posts
I typically tend to use it with a Grid instead of more solid geometry.
>>Kays
- bobc4d
- 327 posts
- OrangyTang
- 12 posts
I've just been trying the SciFi Panels node and every time I actually connect it to any geometry Houdini just hard crashes. I'm just connecting it to a single quad. Does it still work?
The crash log has this callstack:
Crash report from John; Houdini FX Version 18.0.348 [windows-x86_64-cl19.16]
Uptime 367 seconds
Wed Oct 7 12:35:43 2020
Caught signal 11
Traceback from 8748 ThreadId=0x00005274
CURRENT THREAD 21108
+0x221032a8 [UT_EmbeddedTriangleMesh<GU_TriangleMeshDetailLinkT<float> >::operator=] C:\Program Files\Side Effects Software\Houdini 18.0.348\bin\libGU.dll
+0x22108edd [GU_TriangleMeshT<double>::buildMesh] C:\Program Files\Side Effects Software\Houdini 18.0.348\bin\libGU.dll
+0x1a31e340 [SOP_Measure_2_0Parms::copyFrom] C:\Program Files\Side Effects Software\Houdini 18.0.348\bin\libSOP.dll
+0x1a31bdd5 [SOP_Measure2::buildTemplates] C:\Program Files\Side Effects Software\Houdini 18.0.348\bin\libSOP.dll
+0x1a2ce342 [SOP_MeasureParms::version] C:\Program Files\Side Effects Software\Houdini 18.0.348\bin\libSOP.dll
+0x1a346b6a [SOP_Node::cookMyselfAsVerb] C:\Program Files\Side Effects Software\Houdini 18.0.348\bin\libSOP.dll
+0x1a31e022 [SOP_Measure2::cookMySop] C:\Program Files\Side Effects Software\Houdini 18.0.348\bin\libSOP.dll
+0x1a3459ad [SOP_Node::cookMe] C:\Program Files\Side Effects Software\Houdini 18.0.348\bin\libSOP.dll
+0x1201f48a [OP_OTLOptions::operator!=] C:\Program Files\Side Effects Software\Houdini 18.0.348\bin\libOP.dll
+0x1202cd6f [OP_Node::cook] C:\Program Files\Side Effects Software\Houdini 18.0.348\bin\libOP.dll
+0x1204af6b [OP_Node::internalCookInput] C:\Program Files\Side Effects Software\Houdini 18.0.348\bin\libOP.dll
+0x1204fb4a [OP_Node::lockInput] C:\Program Files\Side Effects Software\Houdini 18.0.348\bin\libOP.dll
+0x1a34e5d0 [SOP_Node::lockInput] C:\Program Files\Side Effects Software\Houdini 18.0.348\bin\libSOP.dll
+0x11f14fa1 [OP_AutoLockInputs::lockInput] C:\Program Files\Side Effects Software\Houdini 18.0.348\bin\libOP.dll
+0x1a343f12 [SOP_Node::cookGuide] C:\Program Files\Side Effects Software\Houdini 18.0.348\bin\libSOP.dll
+0x19d480fe [SOP_NodeVerb::cookInputs] C:\Program Files\Side Effects Software\Houdini 18.0.348\bin\libSOP.dll
+0x1a345cfc [SOP_Node::cookMyselfAsVerb] C:\Program Files\Side Effects Software\Houdini 18.0.348\bin\libSOP.dll
+0x1a33cd83 [SOP_Node::AttribTupleIndexArg::operator int] C:\Program Files\Side Effects Software\Houdini 18.0.348\bin\libSOP.dll
+0x1a34a7c1 [SOP_Node::getCookedGeoHandle] C:\Program Files\Side Effects Software\Houdini 18.0.348\bin\libSOP.dll
+0x19e4d3b4 [SOP_BlockEndFor::cookMySop] C:\Program Files\Side Effects Software\Houdini 18.0.348\bin\libSOP.dll
+0x1a707818 [SOP_Switch::cookMySop] C:\Program Files\Side Effects Software\Houdini 18.0.348\bin\libSOP.dll
+0x1a57b5bd [SOP_SubNet::cookMySop] C:\Program Files\Side Effects Software\Houdini 18.0.348\bin\libSOP.dll
+0x1a37fafd [SOP_Output::cookMySop] C:\Program Files\Side Effects Software\Houdini 18.0.348\bin\libSOP.dll
+0x1204fc3b [OP_Node::lockInputs] C:\Program Files\Side Effects Software\Houdini 18.0.348\bin\libOP.dll
+0x1a34e7c4 [SOP_Node::lockInputs] C:\Program Files\Side Effects Software\Houdini 18.0.348\bin\libSOP.dll
+0x1a40512d [SOP_PolyExtrude2::cookMySop] C:\Program Files\Side Effects Software\Houdini 18.0.348\bin\libSOP.dll
- vusta
- 555 posts
OrangyTangdid you enable generate new uvs ? or even update it from the ancient 348 version ?
The crash log has this callstack:Crash report from John; Houdini FX Version 18.0.348 [windows-x86_64-cl19.16]
Uptime 367 seconds
Caught signal 11
just works…
Edited by vusta - Oct. 7, 2020 19:16:25
- manuel huertas
- 1 posts
