import os import sys import hou import time import itertools def generate_menu(): menu_item = [] array_paths = work_item.attribArray("full_path") array_dirs = work_item.attribArray("filename") for path, dir in itertools.izip(array_paths, array_dirs): menu_item.append(path) menu_item.append(dir) return menu_item
Create a menu from work items?
978 0 1- TRex92
- 35 posts
Hi all, Is it possible to create a menu from work items. I have created a list from the work items using a python script top but I'm not sure how to go about creating a normal menu from this list any ideas or is this even possible?
