How to create Guide curve in Lop viewer?
2270
8
0
jerry7
Oct. 21, 2021 3:51 a.m.
Hi, Guide curve can be created in Sop by setting only display flag. I want to create the same guide curve in the lop network just like the Camera/Light icon. How to do it? Thanks!
Faitel
Oct. 21, 2021 4:41 a.m.
Are you meaning guide curve for hair or curve for following path?
Faitel
Oct. 21, 2021 4:52 a.m.
If you meant to create curve for following then there is node called Follow path constraint. It's requiring a curve imported from SOP context and any object.
Edited by Faitel - Oct. 21, 2021 05:03:52
jerry7
Oct. 21, 2021 5:09 a.m.
Faitel Are you meaning guide curve for hair or curve for following path?Thanks for the repliy!
I want to create an ICON with curves like the Null Sop. They are not in the final renderer but display in the viewer.
Faitel
Oct. 21, 2021 6:36 a.m.
You can use SOPCreate node with Control node inside, unpack the geo ether in sop or in SOP import settings (Primitive Definition - Packed primitive - Unpack) and then hide it from render by setting Purpose = Proxy/Guide token through Configure Primitive LOP.
Edited by Faitel - Oct. 21, 2021 09:56:05
jerry7
Oct. 21, 2021 7:44 a.m.
Hi Faitel, The proxy geo is still being rendered if switching to karma. I want it like the light icon that keeps as OGL wireframe even in karma delegate.
Faitel
Oct. 21, 2021 8:42 a.m.
It seems those ogl wireframe guides are pre-built by devs for different primitive types under the hood of solaris.
Edited by Faitel - Oct. 21, 2021 10:52:17
Faitel
Oct. 21, 2021 8:55 a.m.
Regarding visibility you need to enable/disable guides in display settings
Edited by Faitel - Oct. 21, 2021 10:51:51
jerry7
Oct. 21, 2021 11:52 p.m.
Thanks for your replies!
