Hi Everyone.
Trying to solve this problem:
I have a bunch of primitives: ABCDEFGH...
On every new frame I want to have a random selection of these primitives to run a code for, N number of frames.
The selection will always have the same number of prims.
The code that I want to be executed:
Random primitives get assigned an attribute f@foo with value of 1 descdending to 0 for N frames.
Example:
Frame 1 Prims A, C, F (while @foo>0 @foo=@foo-1/N)
Frame 2 Prims B, H, E (while @foo>0 @foo=@foo-1/N)
Would appreciate any pointers. I can't get my head around it.
VEX / Solver: run for N frames if condition is met
887 1 0- Robot_and_Robot
- 30 posts
- 8575 posts
sounds like you can easily do it without any solver just single Primitive Wrangle
- assuming each primitive already has i@foo value
- define for each prim what frame you want it to start decreasing i@start_frame (like prims A,C,F would have it's value 1, B,H,E 2, etc.)
then append Prim Wrangle:
EDIT: this is a simple decrement by 1 from the i@start_frame, feel free to customize for your logic
int decrease_amount = clamp(floor(@Frame) - i@start_frame, 0, i@foo); i@foo -= decrease_amount;
Edited by tamte - June 25, 2022 18:10:56
