vellum solver dop internal value error?
794 2 0- sda502
- 37 posts
- Enivob
- 2536 posts
It looks like order of operation, right? The code fetches the value for stiffness, which is 8, multiplies it by the fall off, let say it 0.5 on this frame. That produces a 4 result, which the max function evaluates as larger than 1. The 4 is stored in the stiffness field and gets multiplied by 0.01.
Try resetting the 0.01 to 1.0, and multiply the value of stiffness by 0.01.
Another way to approach this might be with a fit if you want to specify a specific range for the mops_falloff.
stiffness = max(a*(stiffness*0.01),1);
stiffness = fit01(a,4,8);
Edited by Enivob - Aug. 7, 2022 10:34:22
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
- sda502
- 37 posts
Now I realised that I was misled to think the code fetched the value for stiffness premultiplied by the order of magnitude, which equals 0.008, also the stiffness value resulting from the vex code was the final stiffness value the machine reads for simulation.
Thank you so much, Enivob.
Edited by sda502 - Aug. 7, 2022 11:40:03
