I had this happen a few times. I write code in the Python Source Editor, then I restart Houdini and all my changes are gone.
Just lost last evenings coding which is not great.
Am I doing something wrong? What would be a better way of writing the code? I downloaded pycharm, but not sure how to integrate it in Houdini.
Currently what I do is I write my functions in Python Source Editor and then I call functions in the Python Shell which is a bit primitive.
Python Source Editor does not save when I close Houdini
1369 7 0- AndreasOberg
- 117 posts
- SWest
- 311 posts
You could save the code in a node network or import it from a chosen location. Just storing it in an editor will vanish as you noticed.
If you put it in a shelf it is saved.
Edited by SWest - Oct. 14, 2022 06:01:08
- AndreasOberg
- 117 posts
- SWest
- 311 posts
- BabaJ
- 2039 posts
- AndreasOberg
- 117 posts
BabaJThe odd thing happeneing to me and my collegue is that it is saved sometimes. So I can open the file next day and then I have lost what I wrote in the evening. Not sure what is going on.SWest
Actually, it is saved - but only in the hip file in which it was created. New instances of Houdini won't have it.
- AndreasOberg
- 117 posts
I would like to build a library with python functions that are available in all Houdini scenes.
Any idea on how to do this?
What I did setup the PYTHONPATH environment pointing to a folder, then I created a python file there vf.py
I can now import this from the Python Shell.
One big problem though if I change the code for this vf.py file it will not register in Houdini until I restart.
That means every time I change the script I need to restart which is not great.
I just cannot figure out a good workflow to work with python in Houdini yet.
- graham
- 1906 posts
Putting all your code in an external module is the best way to go about it so that all files can access it. In terms of reloading, you can manually run a Python reload on your module when you've made changes that you want to pick up immediately.
Alternatively, you could shove it all into an HDA's PythonModule section (so that you can edit in Houdini and changes happen immediately) and refer/execute it from there via some convoluted means as long as the HDA is installed in the session.
