Hello all,
My workflow often consists of importing a low poly geo from some other software (say Sketchup) to Houdini and then procedurally manipulating the geometry in order to produce real life mimicing imperfections (wear and tear) and variation. The weak spot of proceduralism in my workflow is often subdividing the incoming geo in order to get enough data to distort with noises and other procedures. All is good if the incoming geo is more or less even in its proportions (say a square or a cube) but I run into issues if there is a significant difference in its proportions (say very long and thin) since the basic subdivision sop gives me a very uneven "resolution" in the two or three axis I'm working in.
Is there a sop/asset that would subdivide any input geo and output an evenly distributed rectangular mesh? Remesh of course does this but it becomes easily very slow the random triangular mesh it produces is often not ideal to model human made objects with (more or less) even surfaces and edges. Or should I try to build my own by combining for instance the Labs polyslice and subdivide sops?
best,
Jaakko
(Un)evenly distributed subdivision
1252 3 1- pietjaakko
- 4 posts
- animatrix_
- 4515 posts
Try Divide SOP -> Bricker.
- Andr
- 900 posts
pietjaakko
best,
Jaakko
you could try Labs Fast Remesh (maybe in adaptive mode?) and see if it speeds up your workflow.
- pietjaakko
- 4 posts
