Quality of life for Houdini users
   31308   106   9
BabaJ
As for myself, I've never had any glitches or difficulties for the 5 years I've been using external includes.
it definitely depends on pipeline and size of the team and how ad-hoc you are used to work also on error tolerance and amount of responsibility
I was talking more from the perspective of scalable system that needs to account for versioning and HDA/code sharing among many shots and long periods of time, so you don't want to risk changing a live code that dozens or hundreds of hip files use, that's why I like the idea of having vex library in versioned HDA as then single environment can still have access to multiple versions
BabaJ
You actually told me how to do that a while back
if only my memory lasted that long, as I wanted to be able to include from HDA extra files section for so long so it surprises me if I knew how at some point but forgot, lol
CG Supervisor
Framestore, NY
we need better tools to import ai/eps/stp files,we need better font tool also.
Edited by wanglifu - April 2, 2023 22:14:16
wanglifu
we need better tools to import ai/eps/stl files,we need better font tool also.
Yes I would agree with .ai one - but what issues do you have with .stl? I routinely export/import them from Houdini with no issues, at least for my purposes.
-rmb/assign shortcut... for nodes, options, ui buttons and window tabs (for the tabs to be used as pop-ups)
-drag and drop nodes to pie menus to replace or assign nodes to empty or occupied slots. Same thing on new empty windows to drag and drop nodes and make your own tool palettes to be used as pop-ups binding them to a shortcut (-rmb/assign shortcut... on its header)
-holding alt+mmb while orbiting to snap to different orthographic views like in plasticity
-Symmetry selections and select similar.
-Be able to set the render flag in materialx and VOPs nodes.
-Good looking gizmos
-The groups widget is kind of annoying. It should be great to visualize groups through the info panel by clicking on the group name, just like you do with attrs.
-Focus on elements when double-clicking them in the spreadsheet (as it happens in unreal PCG).
-Shortcuts like blender to bypass any ui or guizmo interaction like R+R to rotate with the trackball, G+G to slide points on edge, typing in the viewport g+x+value (move+axis_constraint+amount).
-A UI option to give visual feedback to track params that differ from their default value (either colored values or param names, a highlight, or a red border in the param field). How many times have you messed up too much with params and ended up reverting to factory defaults? This is also intended to improve the quality of life when watching tutorials, especially breakdowns.
-An option to normalize all Vellum parameters to 0-1 range, for those who don't want to deal with parameters that operate in unknown ranges of millions of decimals. That would be like setting a game from hell to chicken mode.
Edited by Carlos_Rivadulla - April 14, 2023 18:42:36
A Better Vex code window
Find and replace + vim bindings in code editor. whould be great.
on a small side note. i have tried following multiple tutorials on getting hython to work in vscode but whatever i try it doesn`t work.
if a 1 click extention for vscode was made that just always works, that whould be great !
also viewport not randomly jumping to object level when you combine certain operations. like tab selecting a awrangle in the vieuwport when you dont have the correct selection type enabled. there are others but i an`t find these of the top ofg my head.
This feature request came up in this, and other threads several times already, but please, undockable menus !
I find it amazing that with the default Houdini GUI we still have to dive three levels deep into a menu again and again. I keep running into this and its sooo frustrating, with repetitive tasks it would speed up the workflow a lot ...
And with Alexey Vanzhula's Modeler addon for Houdini one can magically undock the menus, just like that.
So this definitely seems possible.
