Compiling SOP issues
   693   2   0
Hello everyone! Is it necessary to compile SOP without using the for loop?
It's not necessary to compile SOPs
But compiling can have advantages even when not using for each
it is however necessary to compile SOP network if you want to evaluate it using Invoke SOP for example
那些
Thank you! With your official response, I took a reassuring pill. I used to be very confused and anxious, and no one gave an accurate response. Will Invoke SOP calls be faster than traditional calls? For example, will point (../) detail (../) be slower than Invoke SOP? That kind has more advantages. Is it recommended to only use Invoke SOP to call in the future.
