Hello guys.
I have a VEX problem. I want learn a way to check my points have certain count of neighbors (I specify like let's say 3) within a given search radius (Donno this is correct, but something like neighborcount). If that point doesn't have certain amount of neighbors, i want to delete that point.
For example point 24 (red circle), I want to check if that point has 3 neighbors within the radius (blue circle). So it found only one. So, the point 24 will be deleted.
And I want to do this to all points (For loop type)
Can someone please help me ?
Thank you. Have a nice day.
Check if a point have any neighbors
2217 2 2-
- Tashmika_VFX
- Enivob
- 2658 posts
Review the docs on nearpoint and nearpoints. It should get there, along with removepoint.
https://www.sidefx.com/docs/houdini/vex/functions/nearpoints.html [www.sidefx.com]
Edited by Enivob - Aug. 28, 2023 14:50:08
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
- eaniix
- 68 posts
attribute wrangles (except detail wrangles) are forloops already anyway because eg a point wrangle executes the given code for each point.
this should solve your answer, you can use the created slider to control the search radius
float maxdist = chf('maxdist'); //create slider for search radius int neighbors[] = nearpoints(0, @P, maxdist); //create an array listing all neighbors within the search radius removevalue(neighbors, @ptnum); //remove itself from array int numberOfNeighbors = len(neighbors); //get number of neighbors if(numberOfNeighbors < 3){ removepoint(0, @ptnum); //delete point if it has less than 3 neighbors }
Edited by eaniix - Aug. 29, 2023 05:56:22
