Decoupling Scatter Density with Input Geo
1011 5 2- nd_sliu
- 15 posts
I need to scatter onto a low-resolution input mesh, with a high-resolution point cloud representing the density.
Ideally I don't want to remesh the low-resolution input mesh at all. Is there a way to scatter points based on the point cloud's density attribute?
OR
alternatively, can we scatter points on a point cloud? Then I can always snap the scattered points to the closest surface on the input mesh. But scatter works only on surfaces...
Would appreciate any advice/discussions!
(This is a simplification of the problem. I promise there is real application for this!)
OR
Edited by nd_sliu - Oct. 25, 2023 19:26:08
- kushdas
- 3 posts
- nd_sliu
- 15 posts
Thanks! I checked out your solution and it's interesting. Though one great property of the geometry-based scatter is that the scattered density is independent of the geometry resolution. (see variant-res-scatter-output.png)Using the raster method, you can see that the scatter density is actually affected by the grid resolution.
I was hoping to find a solution that gets similar results as the scatter node.
The reason I don't want to modify GEOMETRY is that those kinds of operations are slow. I tried Remesh, Polyslice, and Voronoi Fracture to make it match the resolution of the high_res_grid (which ideally should be 1024x1024). But they all turn out to be super slow. Maybe there can be a faster way to "gridify"?
Edited by nd_sliu - Oct. 27, 2023 15:44:21
- Andr
- 900 posts
I assume that the point cloud should match the size of the base geometry?
In which case, why don't you scatter from the Point Cloud itself?
Similarly to what Kushdas proposed, you can use Point Generate Sop at your advantage, to generate points from the PC, based on a density attribute.
Then you have to jitter them around a bit because the new points are generated at PC positions.
And finally relax them.
Edited by Andr - Oct. 28, 2023 06:58:14
- animatrix_
- 4523 posts
You can also try an adaptive approach:
- nd_sliu
- 15 posts
