Conform modifier
   2462   6   1
So I'm trying to align my thinking from Max to H, and today I was looking at the new conform modifier. What would be an approach in Houdini to achieve something similar? -especially interesting being the volume preservation option.
Rather, how would you even call it in H?
Link to conform modifier in Max [help.autodesk.com]
Edited by coccarolla - Nov. 20, 2023 18:09:49
Read the help cards for the creep node or the ray node.
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
If interested, here is an experimental file (trying to reimplemented some examples)
Edited by Aizatulin - Nov. 25, 2023 10:15:12
conform_modifier.hipnc (502.9 KB)
conform_modifierA.hipnc (597.9 KB)
conform_modifierB.hipnc (759.5 KB)
Aizatulin
Thank you. I peeked at the file and had a little scare there. Will look again with a bit more courage.
Enivob
As far as I can tell creep only works with Nurbs base surfaces, if you want something that works as expected out of the box, and ray could probably work but not with additional steps.
Sure ,
the method is very experimental and I don't have a good idea at the moment to make it more straight forward without adjusting many parameters. But I think there are more elegant solutions out there (especially for the shrink wrap cases, with multiple direction rays).
Here's a couple of examples.
https://forums.odforce.net/topic/51433-conform-objects-to-the-surface-of-another-in-houdini-zbrush-matchmaker/#comment-232857 [forums.odforce.net]
This one conforms a flat logo to a surface before the extrusion process.
https://forums.odforce.net/topic/24894-conform-object-to-surface/ [forums.odforce.net]
