I'm trying to edit some capture weights of an imported FBX rig in H20.
In 19.5 one can isolate only the selected points in the Speadsheet, but this no longer seems to work in H20 ?
Doesn't seem to matter if "show all points in selection" is active or not, the Spreadsheet always shows all the points in the object.
Or am I missing something ?
Edit Capture Weights H20
852 5 1- toonafish
- 413 posts
- CYTE
- 684 posts
- toonafish
- 413 posts
- CYTE
- 684 posts
- toonafish
- 413 posts
CYTE
Sorry, I guess I misunderstood you. I thought you were referring to the normal Geometry Spreadsheet.
Ah, nope this one, just a single point selected :
Just tried it in 20.0.547 but same difference.
Also seems the Edit Capture Weights from the rigging panel is either broken, or working differently from 19.5
I select some points on the captured geo, and hit "Edit Capture Weights" from the Rigging panel, but then I can't select any components when I open the Spreadsheet.
From the docs :
"Select the points to adjust capture weights.
Click the Edit Capture Weights tool on the Rigging tab.
Click the Spreadsheet button on the operation controls toolbar and modify the weight values."
But no luck in H20 so far ..
Edited by toonafish - Dec. 6, 2023 11:34:59
- toonafish
- 413 posts
