how should i setup permanent default paramaters when adding nodes in Houdini 20.5? We have recipes system now but I don't see an option to set defaults. Under "Legacy Presets" is still option to "Save as Permanent Defaults" but is it correct to use it, since it is an outdated system?
Node Permanent Defaults with Recipes
1873 6 1-
- Dawid Wizor
- 33 posts
- kodra
- 373 posts
https://www.sidefx.com/forum/topic/97161/ [www.sidefx.com]
I just asked the exact question. No answer so far, sadly
- BabaJ
- 2162 posts
Dawid Wizor
What do you mean by 'correct'?
You could say have a recipe and apply it - then also go to Legacy Presets and Save as Permanent Defaults.
Or just set up your desired preset and save as permanent default.
- Dawid Wizor
- 33 posts
BabaJ
I assume there is a reason they added "legacy" to the name of these options. This suggests that these options shouldn't be used in first place, because we have new, better features(and maybe one day they will be removed). So they left it in software for people who used them before the update, so that they don't lose their presets, and can have time for switch to new features. Otherwise, calling it legacy is misleading.
Edited by Dawid Wizor - July 21, 2024 11:18:18
- BabaJ
- 2162 posts
Ok, I see...but I guess it's a matter of perception - I would consider it not misleading but rather usefull if one has never used presets before.
'Because what you are about to use is legacy...why don't you go over here and use this instead...you might like how it works...'
Just helps differentiates to indicate two different systems rather than one with improved features.
Edited by BabaJ - July 21, 2024 13:40:36
- ikoon
- 230 posts
- BabaJ
- 2162 posts
