How to get token (not index) value from a ordered menu parm?
   2025   9   0
When we use ch() to access an ordered menu parameter's value, it returns the index (0, 1, 2...) not the token (prim, point...). Which is troublesome in some cases.
For example, I have this setup:
I try to refer Group SOP's group type from Attribute Mirror SOP's group type. However, it doesn't work as expected:
Because 'Primitives' is at index 0 for Group SOP's menu, while 'Vertices' is at the index 0 for Attribute Mirror's menu, when I select Primitives, Attribute Mirror's menu changes to Vertices.
Is it possible to access the token ('prim') so it can reliably read the correct value without depending on the specific order of menu items?
ordered_menu_token.hiplc (100.3 KB)
Screenshot 2025-02-18 223240.jpg (19.5 KB)
Screenshot 2025-02-18 223518.jpg (34.6 KB)
Screenshot 2025-02-18 223503.jpg (21.4 KB)
I don't know hscript, but using a Python Expression you can use hou.parm("grouptype").evalAsString()
alexmajewski
Thank you for the answer. However, I just realized that I misunderstood the issue.
It's not the problem to get token value (in Python, evalAsString() as you said; in HScript, chs()). But the problem is that the ordered menu can't take an expression that returns string as its input.
So in my case, even Attribute Mirror can get the token value (via evalAsString() for example), I can't use the expression to set the menu value...
As the image shows, even the expression correctly gets the token ("point"), the ordered menu doesn't accept this string value.
Screenshot 2025-02-18 225231.jpg (114.3 KB)
I see what you're saying. These two menus have different tokens, that's why it doesn't work. "point" vs "points", "vertex" vs "vertices" and "primitive" vs "prims". The only thing these two menus have in common are their labels. So you would like to set them using a label, is that right?
Edited by alexmajewski - Feb. 18, 2025 10:23:00
Ordered Menu parms are integer, so you can't set them directly using string value, so:
1. for your menus, you can use String parameter with menu and then chs() will work
2. however for factory nodes especially HDK ones, where you can't change type from ordered menu or integer to string you can try something like this to figure out the index within current parm's menu
ref = hou.parm("../grouppromote1/totype1").evalAsString()
menu = hou.parm( hou.expandString("$CH") ).menuItems()
if ref not in menu:
    return 0
return menu.index( ref )
Edited by tamte - Feb. 18, 2025 10:31:47
ordered_menu_token_fix.hipnc (99.3 KB)
CG Supervisor
Framestore, NY
hou.expandString("$CH") is interesting usually use pwd with parm name - thanks for sharing.
or
3. for menus that don't have compatible names you can also create custom mapping tailored to the specific parameter pair, so less generic, but that may not matter, in Hscript it would be something like:
atof( arg( "3 1 0", ch("../grouppromote1/totype1") ) )
CG Supervisor
Framestore, NY
vikus
you can also directly use $CH in hscript, which is also very handy for expressions that depend on parameter name
CG Supervisor
Framestore, NY
tamte
or
Thank for all your answers. I eneded up using arg(). Surprisingly, Houdini seems to automatically convert string to int. It works even without atof().
