Amateur Needs Help, Find shortest Node related
   920   5   2
Hey god folks of Houdini,
This is what I wanna go for;
This is where I am at -
I am trying to use find shortest path.
But some points in the mesh are being left behind. I want to cover all of them going downward.
I have also tried using for each loop, to experiment.
Clearly need some guidance or tips.
Am I working on the wrong thing to achieve my goal?
Is there something else I should try?
Would love to hear any inputs!
Also attaching the Apprentice file I am at.
Thanks in advance, I'll be active to any of Your responses!
^_^
Edited by designsbysarthak - July 17, 2025 03:19:22
XtryX 02.hipnc (447.1 KB)
The - Copy02.obj (12.4 MB)
Why don't you check the post after you write on the forum?
Images are not shown, and a model file should be attached with the hipnc file.
Edited by ifree - July 15, 2025 22:01:34
Updated the same !
Thanks for pointing it out.
Here's a different approach using Boolean Shatter and then converting the seams to curves:
XtryX 02_shatter.hipnc (463.1 KB)
Okay, so this is what I realize.
I want to simulate growth downward on the surface.
This might seem way beyond my limits. But I still want to attempt it.
To achieve the look I wanna go for.
I would love any hints or guides.
Wish me luck or guide my journey my good friends.
ps- I can totally sculpt this. But in the spirit of Houdini and its madness, I persevere.
designsbysarthak
You can also trace flowlines on arbitrary geometry using this technique:
