Height Fields Tracing Mismatch
   291   2   1
How to avoid mismatching borders when tracing height fields with increasing thresholds?
Edited by Konstantin Magnus - Aug. 26, 2025 10:36:59
traced_hf_mismatch.hip (171.4 KB)
This seems tricky, since it's going to interpolate between the voxels.
You could fuse to a grid after tracing, using the grid spacing of the hf (and maybe a slight smooth after)
Otherwise you'll probably need to cook up a trace that does not interpolate between voxels.
Edited by AslakKS - Aug. 27, 2025 15:53:39
Thank you AslakKS,
I ended up setting the tracer's boundary color to a really low value which seems to avoid this issue.
Edited by Konstantin Magnus - Aug. 28, 2025 06:25:16
height_field_trace_foreach.hip (371.8 KB)
