karma cpu/xpu threads control for viewport and live render
   385   4   2
Hi all,
In H20.5 and H21 karma, is there a way to control the number of CPU/XPU threads used during viewport rendering and live rendering (the live render node in H21). Not talking about Local clones.
I would love to save some threads for UI, remote deskstop, and other stuff.
The info I can find is for USD_render_ROP that has to do with render to disk. Or it's setting on the OS level that is trying to limit the total threads used by Houdini. Neither is ideal.
Cheers.
We don't currently expose a dedicated control for reserving threads in Live Renders, but do have an open RFE to add this.
As a work around, I've found you can explicitly set the reserve threads count if you dive into the liverender 'USER_AREA' and use a wrangle to modify your rendersettings prim
i@karma:global:ipr_reserve_threads = 2;
Edited by Ben Toogood Aardman - Feb. 3, 2026 12:06:16
Screenshot 2026-02-03 165229.png (48.2 KB)
robp_sidefx
Thanks for the update, Rob. Looking forward to seeing a features like this added. I am hoping it will work with both live render and viewport rendering.
cheers.
Ben Toogood Aardman
Thanks so much Much, Ben. I'll give this a go.
