Storing a ramp as a per point attribute?
   1286   2   0
We're all familiar with using Houdini's ramps UI to manipulate existing attributes, but what if we whished to store the "value" of a ramp parameter AS an attribute? I know there's a mathematical definition that describes a ramp curve (or just about any curve), but is there a simple way to access this representation from a ramp parameter and store it as an attribute, and then reference this curve in a vex wrangle?
Or would the best way to do this be storing the ramp parameter's path as a string, and then using chramp()?
If you're doing something like morphing the location of points in a mesh from one location to another, being able to do something like randomly assigning some percentage of the points to use a quadratic interpolation vs a linear interpolation would be useful!
Having a direct reference to a ramp parameter would be useful, so you could make adjustments to the ramp on the fly using houdini's competent ramp UI.
Edited by wyhinton1 - June 24, 2024 18:22:58
use Attribute From Parameters SOP to store ramp parameters as string, check Flatten Ramps
then you can evaluate those at any position using ramp_lookup() [www.sidefx.com]
or use ramp_unpack() [www.sidefx.com], ramp_pack() [www.sidefx.com] to alter or create that string in VEX
CG Supervisor
Framestore, NY
You could also loop directly over each point of a ramp:
// DETAIL WRANGLE
float shape = chramp('shape', 0.0);
int num = chi('shape');
int pts[] = {};
for(int i = 1; i <= num; i++){
    string name = 'shape' + itoa(i);
    float x = chf(name + 'pos');
    float y = chf(name + 'value');
    int pt = addpoint(0, set(x, y, 0.0));
    append(pts, pt);
addprim(0, 'polyline', pts);
