(Solved)Trying to sweep modular pieces on curve?
   765   6   1
Hi guys
just trying to work out how to place different modular sections on a curve. placing them on points is not working for me, as they only line up if the curve is strait.
Edited by Getyamamout - Aug. 18, 2026 11:02:59
Hi Getyamamout, have you looked into the chain node yet?
https://www.sidefx.com/docs/houdini/nodes/sop/chain.html [www.sidefx.com]
It "repeats one or more pieces of geometry along a curve".
Ah Konstantin Magnus
Chain is doing a better job just need to have it a bit smoother and let the ends merge into each other a bit
Ah ha didn't realise I could use more points on the curve, with this node to get a more rounded look.
And the joint was offset by -3mm in the alignment tab.
Here is the next question... can I use the chain with G-splats???
The chain node should be fine as long as your input is correct.
Edited by Konstantin Magnus - Aug. 18, 2026 09:23:24
barb_wire.hiplc (293.5 KB)
Thank you for your help Konstantin Magnus.
