H9 and Hardware Shaders
5773 5 1-
- igor_donev
- 133 posts
- wolfwood
- 4344 posts
- edward
- 8081 posts
- madjestic
- 326 posts
edwardHey Edward,
Note that it is an experimental feature you use at your own discretion.Most of the OGL2 Surface SHOPs require uv's on the geometry before you see anything. Finally, they have not been updated in a while so the code may not work anymore. You can see/modify the source code in $HH/ogl2.
Thanks for the info - not that I wasn't aware of OGL2 support but simply didin't have opportunity to dig it further.
Could you eleborate a bit more on how to create custom OGL2 shaders? (I mean the process of creating an OTL for an OGL2 shader) - Is it the same as an OTL for VEX Type Surface Shader Operator, with a different render mask (OGL OGL2), so that the OTL creates the shader UI and then the otl looks for the OGL vertex\fragment sources with the same name as OTL in the Houdini OGL2 dir. Something like that? So simple? I expect there's some trick )
Can we use MILL for creating custom OGL2 shaders, save those as sources, or maybe code our own, place the sources in the dir and use those for custom OGL2 shops?
THanks
I liked the Mustang
- edward
- 8081 posts
- digitallysane
- 1192 posts
