I've found this very old thread
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=13&highlight=lsystem+motion+blur [sidefx.com]
in which Jeff states :
“When point attributes are created, the system's points are
automatically sorted by generation. This means point numbers
will match from generation to generation, allowing motion blur,
etc. ”
How is this helping for motion blur ?
Since the point's count is changing, I still get wild results on new points, when using a trail sop to compute velocities.
Am I missing something there ?
Thanks a lot for clearing things up.
Motion Blur on growing L-system ?
4709 5 3- vinz
- 113 posts
- lisux
- 581 posts
- vinz
- 113 posts
Thanks for the answer.
Well, that's what I tried to do, but I still got weird results.
But I just noticed that the points were correctly sorted only for round generations, 1,2,3,4… not for fractional ones, like 1.1, 1.2, 2.5… so that explains it.
Noticed also that when I manually add a “generations number” attribute, using the t variable, the points which belonged to these fractional generations, had only a fractional part.
For example, I'm at generation 4.3, the last points have a t value of .3, instead of the expected 4.3, which would explain the wrong sorting, if houdini refers to this internally.
So, I got it more or less working, sorting the points using a custom attribute, however the frames where new points appear cause problem, but I guess not much can be done about this.
- lisux
- 581 posts
- anon_user_40689665
- 648 posts
- vinz
- 113 posts
lisux
Maybe you can sorte the points relative to the first point of your plant using the sort SOP, maybe this will give you a more consistent sorting brecause usually this first point never change it's position.
Only guessing …..
I did sort them using the integer part of the generations attribute, so the sorting is ok.
Only thing is that when new points appear I can't use their previous position to calculate their velocity since they don't have any! But that's inherent to the lsystem.
