I am modelling a simple object (tube based) with both ends closed.
While on OpenGL preview it looks very nice, I am experiencing problems with rendering. Screen-shots and sample .hip file attached. Any ideas why it is happening? I did try closing caps in the tube node itself and with special cap node, but both of them gave me problems at the render stage.
Kamil.
Closed caps render problem.
4526 2 0- ka-mi-ru
- 29 posts
- mark
- 2592 posts
kamild
NURBs based?
I'm making this assumption. When the caps are rendered in OpenGL, they are converted to polygons for rendering.
When mantra renders, they are most likely rendered as trimmed Bezier patches.
Try appending a “convert” SOP and try converting NURBs (or Bezier?) curves to either polygons or trimmed Bezier patches.
My guess is that the trimming code has precision issues which are causing the artifacts you see. Converting to polygons might be a better option (just for the end-caps)
P.S. At the moment, I can't run Houdini.
- ka-mi-ru
- 29 posts
