OSX Installation issue
   9536   13   1
Hi all.
Has anyone else had this problem? I've tried 9.5.170/196/197
All bug out on me.
what Mac and which MacOS do you use?
Mac OS 10.5.4
Macbook Pro - 2G of RAM, GeForce8600, Core 2 DUO 2.2Ghz
I've had previous versions installed before without problem, everything seemed to work fine. I mostly use Linux though, so I hadn't really used it much during the beta.
I also have sometimes problems to start houdini… but never had a problem with the installation… If there is no newer version, install a older one which worked before…
The last version I used isn't available for download for OSX any longer.
Besides, I have two HD licenses for 9.1, I want one for my linux box and one for my laptop. I'm not going to upgrade to 9.5 if I can't even install the current version of the software so I'd really rather figure out why my machine is having the problem.
also, does anyone else think it's kind of hilarious to see a big installation error message with the shattering glass in the background? haha
Still no luck regardless of the version. I've created a new user on the machine and tried to install it that way in order to test if this was an error with preferences. No luck.
I've also tried editing the pkg file to remove the offending step of the install, but that was clearly not going to work anyway.
I'm running out of ideas and this is seriously bumming me out.
The console logs just state that they are continuously trying to start sesinetd but aren't able to find the houdini framework. So I think I need to find all of the files that are installed and mannually remove them before attempting another install. I'm thinking something went wrong in a previous uninstall and for whatever reason it's causing errors as Houdini tries to perform whatever function they need to when setting the folder icon.
Is there anyway for me to debug that script? How can I see what's trying to do in order to find out where the error is occurring?
What if you ignored that error? Does Houdini still run?
Thanks Ed. I'll take a look and see what I can figure out.
The installer reports that the module AppKit cannot be found.
So it would appear my python environment is screwed up? I've installed stackless but I thought that was a simple module addition only. hrm.
Ok I'm all set now! Thanks again Ed.
The other version on python installed a symlink in /usr/bin that preempted my system supplied python. I didn't know that!
You mean the stackless python? Anyhow, I'm glad it's all sorted out!
Stackless python indeed. It installed it's own python which I didn't think too much of and it generally didn't affect me.
But in case anyone is interested it installs it's own python into /Library/Frameworks/Python.Framework
and the Apple supplied python is in:
/System/Library/Frameworks/Python.Framework
So if you have a problem with it just be sure your .bash_profile places the system version first.
Very easy to fix. So I guess I installed the wrong stackless installer or something. Oh well.
