Hi there,
I don't know if I'm doing something wrong or just it doesn't work.
I have some sprites, and one material with a constant shader and the geometry shader (geo_sprite) inside.
If I use the material field in the object, pointing to my material it works perfect. But if I put the material in a material SOP it doesn't work, why?!
I just wanna use an attribute override, any guest?!
thanks!
Sprite Attribute Override
5263 5 0- onesk8man
- 32 posts
- Shumberg
- 14 posts
If you are doing an override of something in a multi-component material (for example, a material with surface and displacement shaders, or a surface and geometry shader like your case), the way I have gotten this to work is to promote the parameters up to the material node (right-click on the material ‘Promote Material Parameters’) and then point your material SOP at the material. Then override away…
Also make sure to turn on the ‘Overrides use local variables’ toggle if you want something like $PR to evaluate correctly.
- onesk8man
- 32 posts
- AndrewVK
- 136 posts
- JasonSlab
- 1533 posts
hey
i've been having a few problem with this to, using the Material SOP with overrides, i eventually figured it out, sotra..
if your overriding a map for example, you need to add that attribute to your sprite procedural.
so material SOP override a map, gives you this: vopsurface1_map add this to your procedural and it should work, hopefully
hope that helps a bit
actually, i do find this work-flow a bit confusing and all over the place, i'm pretty used to setting up material SOP overrides with delayed reads, now change this to sprites and it works in a different way, can't help but thinking that the work-flow should be a lot more similar?
at the moment i'm using simple grids as delayed reads for a job, rather than sprites
jason
jason
- AndrewVK
- 136 posts
Take a look at this example.
http://www.sidefx.com/exchange/info.php?fileid=590&versionid=590 [sidefx.com]
I use Python sop to assign point attribute
to override material`s “file” parameter.
It can be done with Attribute Create SOP also…
>>>…but thinking that the work-flow should be a lot more similar?
Totally agree with jason|slab !
This should be normalized in the future
