I hit LOAD to bring up examples of simulations in the houdini apprentice version example files but it doesnt bring anything up. It asks me if I give permission to the local server and I accept but nothing happens. I have tried reloading and even hitting the launch key with no help. Is this something that the apprentice version doesnt allow? Or am I doing something wrong? Thank you.
Hairston
Example files do not load in apprentice
10880 10 2- hairston630
- 96 posts
- Soothsayer
- 862 posts
- MagnusL3D
- 1104 posts
Here's another solution that worked for me on Windows Vista.
Houdini installes default to “C:\Program Files\…”, and the space in the filepath caused a problem.
My solution was to install Houdini to C:\Houdini and not to the default path with spaces in.
After that example files loaded without problems.
/M
/M
- hairston630
- 96 posts
- hairston630
- 96 posts
- Soothsayer
- 862 posts
hairston630Soothsayer
Good luck!
Hi Soothsayer,
Could you explain where you located this and how you did it please?
I wish I could. My OS isn't english so I don't know what the tabs are called but it's something like right-click Mycomputer>Properties>Advanced and then one more click and you get to a window like this:
http://www.cs.usask.ca/~wew036/latex/env-env.jpg [cs.usask.ca]
You create a new variable called HOUDINI_DISABLE_CONSOLE and give it the value 1
Jobless
Jobless
- graham
- 1909 posts
- hairston630
- 96 posts
- hairston630
- 96 posts
Soothsayerhairston630Soothsayer
Good luck!
Hi Soothsayer,
I did everything as you stated but it still wont load the example files. Graham, could you please explain a little more as to what im supposed to be doing when adding another entry? Thank you.
Hairston
- heydabop
- 203 posts
- Kuran2704
- 6 posts
