I would like to paint an attribute that controls the clumping density for fur.
However I can not seem to figure out where to place the parameter…. I thought it would be either in the fur density shop or the fur styles shop.
Any ideas?
Density Attribute?
9362 7 1- Wren
- 527 posts
- Wren
- 527 posts
- derrick
- 329 posts
Wren
Any ideas?
The Fur Object's contained “clumps” network is used to create clump hairs. The skin shader referenced by “clumps/create_clump_hairs” could be updated to implement this functionality.
- Wren
- 527 posts
- derrick
- 329 posts
- Wren
- 527 posts
- Wren
- 527 posts
So finally back at work… I am trying to figure out what you mean by skin shader… or more importantly where I may find it.
Are any of these locations close?
If someone could point me in the right direction It would be much appreciated… Its probably obvious but I am stumped… sigh. :roll:
obj/geo_fur/fur/shopnet1/furdensitymap/furskinglobal1or
obj/geo_fur/clumps/shopnet1/clumporigin/furskinglobal1or
obj/geo_fur/clumps/shopnet1/clumpshape/furskinglobal1/furskinglobal1
soho vfx
- derrick
- 329 posts
Wren
Locate the “clumps/create_clump_hairs” node inside of the Fur Object. This is the SOP that ultimately creates the clump hair geometry. If you inspect that nodes “Attributes -> Skin -> Shader” parameter, you will see it uses the “clumps/shopnet1/clumporgin” shader (this is the shader you want to modify). Hairs can be removed by manipulating the “furdensity” value within this shader. You may wish to consult the “fur/shopnet1/furdensitymap” shader for reference.
