Questions about Pyro
   1786   0   0
Hi,everyone
I'm a bit confused about pyro setup ,need your help,thanks very much in advance.
1.In the uprespyro solver, the setup separates the “Heat production” from the gascombustion and do it in another gas field vop.(see the image below).It seems that the calculation in gas field vop is almost the same as the gas calculate in gascombustion except that the “burn*heatout” is scaled by Timeinc before added to the temperature field. Correct me if I'm wrong.
I cannot understand why the setup do such separation in uprespyro but not do in pyro solver and what's the effect brought up by the Timeinc multiplication?
2.I guess there's some setup error in uprespyro object or I'm wrong again?
In the node “load_lowresburn”(SOP Scalar Field) the data name is lowresburn but the SOP Path is “../load_our_data/TEMPERATURE” which I believe should be “../load_our_data/BURN” and be consistent with the node “get_lowresburn”.
~My Houdini version is 10.0.595
