Voronoi Fracture inherit sop animation
9617 6 1- mickyblue
- 217 posts
Hi there,
I have a sop based animation on a breakable obj.
How can the Dop simulation fallow inherit the sop movment, and not just drop as if the sop movment would not exist.
tried to run the Velocity Transfer in the Voronoi Fracture Parameters, but I don't get it work!
Any advice or suggestions would be nice!
(enclosed the hip file)
Thanks a lot
Thanks a lot
- johner
- 809 posts
I would get the animation hand off working before introducing the fracturing tools. Read this section [sidefx.com] in the Houdini docs about transferring animation to DOPs.
The VelocityTransfer on the fracture node controls how the pieces inherit velocity from the intact object at fracture time.
At the moment you have a tranform at the Object level, and animation at the SOPs level. I would consolidate those to the object level, or, since you want to fracture things later, maybe move it all to an RBD Keyframe Active node.
I copied your animation channels to an RBD Keyframe Active node, and that seems to work fine. Just set the Bypass flag on the fractureParms node while tweaking the animation.
I also set the DOPnet Substeps to 2 since the fracturing transition is smoother when you do that.
- mickyblue
- 217 posts
- johner
- 809 posts
For SOP level animation it depends on whether you want to simulate deforming geometry, or hand off the animation of the object completely to DOPs at some point.
In the first case you can turn on “Use Deforming Geometry”, which does what it sounds like but can be slow as the collision SDF needs to be re-computed each timestep.
For the second case, append a Trail SOP set to Compute Velocity, which adds a velocity attribute to each point of your geometry, then turn on “Inherit Velocity from Point Velocity” on the RBD Object. Then set the “Creation Frame” to the frame when your SOP-level animation ends. See attached for an example of this technique.
- mickyblue
- 217 posts
thanks a lot johner!!!
Thats what i am looking for!!!…but it seem that merge sop and the two incomming dops are somehow erroneous ..or the fechting doesnt work correctly!?
So I used a switch node to blend the situation befor and after the break in one seemless sequenc.
Is there a more elegant way to feed the data back to work properly?
- johner
- 809 posts
- mickyblue
- 217 posts
