Render transmissive object transparency?
   2178   8   2
how to render an object with transmissive materials and get the alpha to respect the transparency in karma XPU?
by default the transmissive areas just renders black!
hou.f*ckatdskmaya().forever()
I think you can do this with the unlit surface material
I assume you should be able to use background B event in LPE
You obviously not get the refraction information but you should get the background contribution for the chosen lightpaths
tamte
Hello @tamte, Thanks for this but don't quite understand how to set this up.
I've added two images here, the one with black shows what I get If I just render the object with nothing in the background and the one with the white bg and white showing in transparent areas is me putting a grid object behind it it the render.
But I want to be able to render with nothing behind it and get the transparent areas instead of black to use this image on a website.
I've also added a hip file if you have the time to show how to set this up.
Thanks much!
transparent_BG_help.hiplc (1.2 MB)
here is an example
1. added transmission_bg_mask AOV using LPE: CT.*B
2. combined it with Alpha in a slapcomp over custom BG
display slapcomp in the viewport to see the result
Edited by tamte - April 21, 2025 20:36:33
transparent_BG_help_mod.hipnc (1.2 MB)
tamte
here is an example
Thanks so much for this @tamte!!!
tamte
here is an example
Hello, where can I get some more information regarding the LPE tags that you've used (CT.*B)?
I've been trying to find this many times but got nothing.
Thx!
razCHS
its not the tag itself, but LPE expression on Render Var
https://www.sidefx.com/docs/houdini/render/lpe.html [www.sidefx.com]
Edited by tamte - April 24, 2025 09:38:08
tamte
razCHS
Never thought searching under Mantra chapters, always looked for it in Solaris or Karma.
Thank you!
