houdini_2_ae for Houdini 21
   3088   6   1
Hi everyone,
I tried to use Houdini_2_AE HDA in Houdini 21, but I get an error Pyside2:
File "Object/houdini_2_ae, PythonModule", line 3, in <module>
File "C:\PROGRA~1/SIDEEF~1/HOUDIN~1.440/houdini/python3.11libs\toolutils.py", line 1903, in createModuleFromSection
return _createModule(module_name,
File "C:\PROGRA~1/SIDEEF~1/HOUDIN~1.440/houdini/python3.11libs\toolutils.py", line 1885, in _createModule
eval(code, module_dict)
File "houdini_2_ae", line 1, in <module>
ModuleNotFoundError: No module named 'PySide2'
Does anyone know what needs to be edited or have an adjusted copy of it?
H21 is built around QT6, which uses Pyside6. You can either specifically instal a QT5 version of Houdini or try to replace all includes of Pyside2 with Pyside6. That's not guarantee to work as quite a few other things have also changed in QT6.
thanks i will try it today
Just to confirm that changing PySide2 to PySide6 in the HDA script works!
If someone needs an updated HDA, i can send it
After replacing PySide2 to PySide6, i've still this error :
Error running callback:
File "Object/houdini_2_ae/lunch_tool", line 1, in <module>
File "houdini_2_ae", line 1087, in show
File "houdini_2_ae", line 70, in __init__
AttributeError: PySide6.QtGui.QPixmap.scaledToWidth(): unsupported keyword 'transformMode'
ebenfred
Add # in line 70-72
70 #self.lb_header_photo.setPixmap(self.lb_header_photo_pixmap.scaledToWidth(
71 # self.lb_header_photo.width(),transformMode=Qt.FastTransformation)
72 #)
thanks ! works well!
cheers!
F.
iam83
ebenfred
Add # in line 70-72
72 #)
