Trigger Animation in DOPnet
809 8 1-
- BSwarth
- 17 posts
I'm attempting to create a sorting machine for RDB objects in a DOPnet. To do this, I need to move a static object based on the position of an active object inside a DOPnet.
To simplify the setup, I have an RBD packed object (sphere) that is affected by gravity. Below the spehere is a tube that is a deforming static object that will serve as the collider.
I'm trying to have the tube move in the negative x direction to hit the sphere when the sphere reaches a specified y-position. Ideally, the position of the tube would reset in order to collide with additional spheres that will be emitted.
I'm having trouble understanding how to trigger the animation of the collider based on the position of the falling sphere.
Thanks in advance for any guidance.
Edited by BSwarth - Nov. 18, 2025 20:27:00
- Ferry Taswin
- 8 posts
- BSwarth
- 17 posts
- Ferry Taswin
- 8 posts
- BSwarth
- 17 posts
- Ferry Taswin
- 8 posts
- BSwarth
- 17 posts
- Ferry Taswin
- 8 posts
- BSwarth
- 17 posts
