Intercept Mode: More easily accessible? {[SOLVED]}
   594   1   0
Hi!
I'm using the Keyboard node inside of a Chop Network to record keyboard inputs. For it to work, I have to activate the Intercept Mode so my keyboard inputs won't be used as Houdini shortcuts.
I have to activat/deactivate this option very often so I was wondering if there's a way to access the option more easily. Is there a ways to keep the Edit menu opened (like in Maya)? Or, can I somehow drag that button somewhere in the main interface?
-Olivier
Edited by olivierth - April 25, 2026 15:53:14
-Olivier
this used to be toggleable using Scroll Lock key by default, now it's behind environment variable, so if you put this in yout houdini.env
HOUDINI_INTERCEPT_WITH_SCROLLLOCK=1
you will be able to toggle the intercept mode using Scroll Lock key
