Solaris Arnold: Cant see backfacing polygons [{SOLVED}]
   740   2   0
Hi!
I'm using Arnold to render leaves but I can't see the backside of my leaves (no thickness). Is there a setting for that?
-Olivier
EDIT: I tried a Two-Sided shader and it doesnt change anything.
Edited by olivierth - May 13, 2026 10:23:30
-Olivier
Render Geometry Settings/Arnold/Normals
and switch to Set Or Create any of the double sied properties you want, at least Camera and Shadow, but likely all of them:
Edited by tamte - May 12, 2026 18:26:50
Screenshot 2026-05-12 182556.png (43.2 KB)
AAAHHHH!!! Thank you!!
-Olivier
-Olivier
