Create a Copernicus node with dynamic multi-input
   649   1   0
Is there a way to create a Copernicus node (hda) with a dynamic multi-input?
Similar to how the "Layer Merge" Copernicus node works? where you wire an input and it adds a new input under that one.
So far I haven't been able to figure out how to do this.
looking to get python access to the new "input/output" hda tab format for this type of node?
Any ideas? or is it not something that's supported yet?
thanks
-redpaw
Edited by redpaw - July 1, 2026 18:57:18
I don't know if there is a way without HDK, but you can create a Cable input, then you can pack multiple layers into a cable before passing to your HDA
Edited by tamte - July 1, 2026 21:35:54
