Bulletsolver killzone without dops?
   867   3   2
Hello, I'm working on a simulation tool that scatters debris in Unreal, using the bullet solver.
I'm wondering if there is a way to make kill zone without using dops? I only have a Core license and not access to dop networks. I'm trying to optimize the calculation time.
I would like to stop simulating and remove debris at a certain height, like after the red line on the picture.
Edited by stinzen - Aug. 20, 2026 08:57:51
You could remove them after the simulation, group and blast should do the trick.
Hello. I'm attaching a modified version of RBD Bullet Solver to resolve your issue. It deletes RBD pieces in pre-solve inside the DOP network so it should speed up the calculations.
You just need to install this HDA like any other. Download the .hda file and move it into local Houdini directory (Documents/houdiniX.X/otls/).
Inside your hip file replace default RBD Bullet Solver with this cullzone_rbdbulletsolver. You should see Enable Cull Zone toggle and Cull Height parameter inside the node. Adjust the cull height so you don't delete the collider as well.
I hope it helps!
cullzone_rbdbulletsolver.hda (371.9 KB)
Italimpex Productions
CGI Studio specializing in directing and producing advertisements & films
Thank you Italimpex Productions, amazing, it works like a charm!
FedorK_FX - Yes I have done this, but it's a tool used in Unreal by other users and I want to improve the performance of the simulation itself by removing unnecessary calculations which this cull zone does.
