Abstract Controller Slider Snapping
   711   3   5
In H22, is there a way to disable the axis snapping behaviour on the abstract controls so that it mimics the behaviour from H21? I understand the benefit of disabling blended movement between the X and Y axes for animation, but in my case, I'd like to show off a rig in my viewport and prefer the smoother interactivity from H21 in this particular case.
Edited by AntonMoss - Oct. 20, 2026 18:52:33
H21_vs_H22_abstract_controls_v01_small.mp4 (10.5 MB)
Interested in this.. Following.
Hi, you can use CTRL + SHIFT to do this. There's a small bug where the Y value is not set when using ctrl + shift, it has been fixed and should be in tomorrows build.(fixed)
Edited by william_harley - Nov. 6, 2026 04:07:08
Ctrl + Shift works great in 22.0.495. Thanks for the update.
