Hi!
I need multiple parameters to be hidden depending on a detail integer attribute inside the HDA. How?
I usually drive visibility by channels on the HDA (top level). I've never driven visibility by whats inside the HDA...
HDA: "Hide When" affecte by attribute inside the HDA {[SOLVED]}
283 5 1-
- olivierth
- 1262 posts
- tamte
- 9744 posts
drive it by the invisible integer parameter on the HDA
and make that parameter's default expression read the detailattrib, like: detail("./OUT", "attrib", 0)
just be aware that making UI depend on cooking of the geometry may not always be a good idea, as it will force that geo stream to cook and slow things down, or if its uncooked and in manual mode it may just use 0, may be wrong when observed within foreach block as te UI will likely just reflect the current iteration, hiding the controls that maybe are important to tweak as other iterations may need to use them etc...
- olivierth
- 1262 posts
- olivierth
- 1262 posts
- tamte
- 9744 posts
olivierth
...My goal is to connect multiple assets (packed primitives with names) to my HDA and to have the list automatically fill up like in my image. What would be the best way to do so?
in that case definitely don't make it based on geo unless maybe if you have fixed set of assets that never changes and you just want to control the visibility
if the amount/names of named prims in the expected geo is variable, I'd do a UI with default probability slider which will be a fallback value for any named prim
and then a multiparm, where you can add specific named instances, dropdown one of the names from the current geo's unique name values (or specify a name pattern) and set it's probability, which will internally use it for named prims matching that pattern instead of the default value
you can have a button that will fill the multiparm for you based on one time cook, or just add missing, maybe have enable toggle on each so you(or the button) can just disable ones that are no longer present without losing the value
but definitely keep it decoupled from the geo, since there is nothing worse than UI trying to be too smart and update when the geo is in errored state or empty and wiping out all your values, etc
Edited by tamte - Oct. 21, 2026 14:28:25
- olivierth
- 1262 posts
