VEX xyzdist: distance to a primitive number?{[SOLVED]}
   305   5   0
Hi!
I have no groups on my geo and want my point wrangle to detect the distance to a specific primitive from the second input. Each point searches for a different primitive.
The documentation talks about not needing a group if I use an expresion like: @Cd.x>0 (yet, I tested their example and it does not work...)
Edited by olivierth - Nov. 17, 2026 14:46:22
-Olivier
I tried this:
xyzdist(1, "@primnum==0", @P, primhit, UVs);
but it returns the primitive -1. So thats a fail.
Edited by olivierth - Nov. 17, 2026 14:41:34
-Olivier
maybe share what exactly you tried?
one think to keep in mind is that the attribute in adhoc group string has to be a primitive attribute on the lookup geo
alternatively you can also directly use string of any primitive number or pattern that group parms accept, so not necessarily named groups
olivierth
@primnum is not an attribute so in your case just use
xyzdist(1, "0", @P, primhit, UVs);
AHHHHHH!!!!
Ok, like you were saying (I think), it has to be a primitive attribute visible in the geometry spreasheet (@primnum is not). I created a prim attribute i@primnumREF and now, my script works!
float dist = xyzdist(1, "@primnumREF==3", @P, primhit, UVs);
EDIT: I replied right after tamte...
Edited by olivierth - Nov. 17, 2026 14:47:20
-Olivier
olivierth
I created a prim attribute i@primnumREF...
but again, there is no need for this if you want to match 1:1 prim numbers, just use the prim number directly as a string like mentioned
Edited by tamte - Nov. 17, 2026 15:06:48
