Vertex Normals in Viewport but not in Geometry Spreadsheet?
   201   2   0
Hi!
I imported an alembic file that I unpacked. The Transfer Attributes is set to show all attributes.
When I activate the Display Normals button, I can see the geo has vertex normals in the viewport. Yet, when I look in the geometry spreasheet, there are no normal attribute anywhere.
How can I get the normal attributes to show in the geometry spreadsheet? I don't want to re-calculate normals!
-Olivier
viewport needs normals to be able to shade your polygonal geometry, so if N doesn't exist it will compute it's own normals based on Display Options/Geometry/Normals&Tangents settings
so seeing normals in the viewport doesn't mean the geometry has explicit N attribute
since your geo is already unpacked and if there is no N in the node info, I'd assume your alembic doesn't contain explicit N attribute, therefore nothing to see in the Geometry Spreadsheet
you can also run abcecho command on your .abc file to see whether it contains N or not
ahh, thanks for the info!
-Olivier
