I know this is a very big question… I know there are nice help files…
I just would like to know the workflow? any special mantra settings?
…any geometry exports?
Because I could not see the actual fluids in the final render when I tried to render one of the help examples.
Thanks.
How To Create Fluids in H9.1?
8346 13 1- symbolic
- 107 posts
- probbins
- 1145 posts
- symbolic
- 107 posts
- symbolic
- 107 posts
- havana
- 67 posts
- symbolic
- 107 posts
- probbins
- 1145 posts
That example is not setup to render, it is just to show a dops example.
There's no light or camera, so you'll have to add those.
The most import thing is to get the fluid information out to a geometry node.
I'd dive into the main node and in there create a new Geometry object.
Inside that call in a DopImport sop.
Make the parameter changes you can see in the attached image.
Then add a Delete sop to delete the fluid bounding box. (2nd image)
I usually have the list view open next to the network view so I can see the nodes and drag the paths that I need. (3rd image)
“everything is coincident”
- havana
- 67 posts
- symbolic
- 107 posts
- symbolic
- 107 posts
- Allegro
- 696 posts
- symbolic
- 107 posts
- schyzomaniac
- 69 posts
- Allegro
- 696 posts
