SOP Tangent from the exchange
2617 2 0- Gerome
- 85 posts
- stevenong
- 1631 posts
It is broken due to a change in the Add Attribute VOP. You can fix it yourself if you want.
RMB on the SOP, select “Allow Editing of Contents” and jump in. Look for the build_tangent VOPNET, jump in, select the addattrib__tangent & addattrib__radial VOPs. Change the Type Modifier from “None” to “Vector Data” and the SOP should work as expected again.
I don't know whether to classify this as a bug or compatibility issue. I guess it's an easy fix if you know where to look.
Cheers!
steven
Cheers!
steven
- Gerome
- 85 posts
