hi there,
I was a maya user and now learning Houdini. How to bake a channel into keyframes?(24 keys each second) Should I export the channel to chop to do it? or I could do it inside the channel editor?
thanks for your attention!
bake keyframe
2177 1 0- brucelay
- 313 posts
- probbins
- 1145 posts
Yes, you can do it in chops. Do you just want to place keys on every frame in a quick way? You can do that in the Dope sheet with the edit box. Draw the edit box on the frame range you want and hit “k” to create keys at every frame inside the box.
“everything is coincident”
